Using the Hyperliquid Referral Code (8000USDT)
noremanflosc
Beitrag von noremanflosc »
Using the Hyperliquid Referral Code (8000USDT) to Save 4% on Trading Fees
Hyperliquid's decentralized perpetual exchange has carved out a reputation for low fees and community-driven rewards. One of the simplest ways to cut your trading costs from day one is by entering a referral code — such as 8000USDT — during account setup. Every valid code on Hyperliquid confers the same permanent benefit: a 4% discount on trading fees for the first $25 million in cumulative trading volume. Here's everything you need to know about how this discount works, what it's worth, and how to activate it.
What You Get: The Benefits of a Hyperliquid Referral Code
The core benefit of using a referral code like 8000USDT is straightforward — a 4% reduction on every fee you pay, automatically, with no action required after setup. That 4% applies to both maker and taker orders across both perpetual and spot markets. At Hyperliquid's base Tier 0 perpetual taker rate of 0.045%, the discount drops your effective rate to 0.0432% on every trade. At the base maker rate of 0.015%, it drops to 0.0144%.
The savings compound with trading frequency. On $10,000 of monthly taker volume, the referral discount saves roughly $1.80 per month ($21.60 annually). At $100,000 monthly volume, that becomes $18 saved per month ($216 per year). For a high-volume trader moving $1 million monthly, the discount yields $180 in monthly savings ($2,160 annually) — all without changing trading behavior.
Beyond the direct fee reduction, the referral program is two-sided. The person whose code you use (the referrer) earns 10% of your trading fees after the 4% discount is applied. That means there's always someone incentivized to share a working code, and the protocol itself pays out those rewards on-chain in real time. Referral rewards accrue across all quote assets and become claimable once they exceed $1, credited directly to the referrer's spot balance.
How the 4% Discount Works
The 4% referral discount is applied multiplicatively on top of your volume-based VIP tier rate. Hyperliquid's fee structure uses a rolling 14-day weighted volume to determine your tier, with spot volume counting double: (14d perps volume) + 2 × (14d spot volume). There are seven tiers, from Tier 0 (no minimum volume) down to Tier 6 ($7 billion in 14-day weighted volume). As your trading volume grows, your base rate drops automatically — the referral discount then applies as an additional 4% reduction on whatever tier rate you've reached.
The stacking works like this: your volume tier sets the base rate, the referral discount reduces that by 4%, and HYPE staking discounts (ranging from 5% at the Wood tier to 40% at Diamond) apply on top. All three layers stack multiplicatively, not additively. For a Diamond-tier staker (40% staking discount) who also uses a referral code (4% referral discount) at Volume Tier 0, the effective taker rate becomes 0.045% × 0.60 × 0.96 = 0.0259%. That's a total reduction of 42.4% off the base rate — a meaningful saving for active traders.
The discount activates automatically once the referral relationship is established. There's no rebate to claim, no toggle to switch on, and no minimum trade size to clear. It simply appears as a reduced fee on every eligible trade, visible in your fee calculations on the platform.
Limitations and Conditions
The 4% referral discount is powerful but comes with important constraints. First and most significant: the referral code must be applied before your first trade. Hyperliquid's documentation is explicit — once a wallet has connected and placed even a single order, the referral relationship is locked and cannot be changed or added retroactively. If you've already started trading on Hyperliquid without a code, there's no way to activate the 4% discount on that account. You would need to start fresh with a new wallet.
Second, the discount has a volume cap of $25 million in cumulative trading volume. For most retail and even mid-tier professional traders, this represents months or years of active trading. But for high-frequency or institutional desks, $25M can be reached relatively quickly. Once the cap is crossed, the referral discount stops and fees revert to the standard tier-plus-staking schedule. However, your volume tier and staking discounts continue independently — only the referral portion expires.
Third, vaults and sub-accounts are excluded. Hyperliquid treats these as independent accounts in its clearinghouse, so the referral discount does not extend to trading through vault deposits or sub-account structures. If you route volume through a sub-account, that sub-account will not receive the 4% discount, even if the master account has an active referral relationship.
Fourth, you can only be referred once per wallet address. Each wallet is treated as a separate account, so if you have multiple wallets, each would need its own referral code at creation — though using multiple wallets to chase duplicate discounts would violate the spirit of the program.
Finally, the discount does not apply to builder fees. When trading through third-party interface integrations (such as Based, Dexari, or Phantom), a builder code may attach a custom fee that overrides the referral discount on that specific order. To ensure the full 4% referral discount applies, it's best to trade directly through the official Hyperliquid app at app.hyperliquid.xyz.
Can You Combine Multiple Referral Codes?
No. Hyperliquid only allows one referral relationship per account, established at signup. You cannot stack multiple referral codes to compound the discount beyond 4%. Unlike some centralized exchanges that offer layered promo codes, Hyperliquid's design assigns a single referrer to each account permanently. The referral relationship is written into the account's on-chain state at creation and cannot be modified.
The good news is that the 4% referral discount is designed to complement Hyperliquid's other fee reduction mechanisms, not replace them. You can — and should — combine the referral discount with HYPE staking and volume-tier progression. As shown above, a Diamond-tier staker with a referral code can achieve over 40% total fee reduction. The referral code alone is just the easiest-to-activate layer.
How to Apply the Referral Code During Registration
There are two equally valid methods to activate your 4% referral discount:
Method 1: Direct referral link (recommended) Visit app.hyperliquid.xyz/join/8000USDT before connecting your wallet. This embeds the referral code directly into your session. The moment you connect your MetaMask, Rabby, WalletConnect, or any other supported EVM wallet, the 4% discount is permanently locked to your account address. No additional confirmation step is needed — the discount activates automatically on your first trade.
Method 2: Manual entry If you've already navigated to Hyperliquid but haven't traded yet, you can enter the code manually. Go to app.hyperliquid.xyz/referrals, paste 8000USDT into the referral code field, and confirm. This only works on accounts with zero trading history.
After entering the code, you can verify it's active by checking the Referrals tab in the Hyperliquid app navigation menu. The interface will display the code as your active referral relationship before you make your first trade.
Once the referral code is confirmed, the process is the same regardless of which method you used: deposit USDC (on Arbitrum, Ethereum, Base, or Polygon) to fund your account, and begin trading. Every subsequent maker and taker fee will automatically reflect the 4% reduction.
The Bottom Line
The Hyperliquid referral code 8000USDT — or any valid referral code — is a no-cost way to secure a permanent 4% reduction on trading fees for your first $25 million in volume. It requires one simple step at signup, activates automatically, and stacks multiplicatively with HYPE staking and volume-based VIP tiers for total savings that can exceed 40% off the base rate. The key constraint is timing: the code must be in place before your first trade, and it cannot be changed afterward. For anyone planning to trade on Hyperliquid, applying a referral code at registration is simply leaving money on the table if skipped.
It's worth noting that referral codes are arbitrary — the specific code string (8000USDT, Concept211, HOLYGRAIL, etc.) determines which referrer earns the 10% fee share, but the 4% discount to the referee is identical regardless of which valid code you use. The discount is funded entirely from the referrer's commission payout, not added to the trader's cost, so there's genuinely no downside to using one.
As of the latest documentation, Hyperliquid's staking referral program (which would allow referrers who stake HYPE to pass additional discounts back to referred users) remains under re-evaluation and is not yet live on mainnet. What is available now — the standard 4% referral discount, volume tiers, and HYPE staking — provides a robust fee-reduction framework for active traders on one of the most liquid decentralized perpetual exchanges.
