U4GM Explains AION 2 Mounts, Pets and Exploration Freedom
Eigene Projektseiten? Friendly Forums? ... Hier rein damit.
1fuhd
Beitrag von 1fuhd »
Mounts in AION 2 are more useful than simple cosmetic collectibles. Companions can follow your character, help with auto-looting, and in many cases transform into rideable mounts for ground travel. If you are preparing your character for launch, understanding this system early can make exploration and farming much more convenient. Players planning their early progression can also take a look at Aion 2 Items while preparing their equipment.
How the Mount and Pet System Works
AION 2 connects pets and mounts instead of treating them as completely separate collections. A companion can follow your Daeva during normal activities and then become a mount when you need faster ground movement.
This gives companions several practical uses:
• Follow your character during exploration
• Transform into rideable mounts
• Help with auto-looting
• Add another layer to collection progression
• Provide cosmetic customization
Because of this setup, collecting creatures is not just about filling a collection menu. The companion you choose can become something you use throughout your normal play session.
When Should You Use a Mount?
Ground mounts are most useful when you are traveling through large areas without needing to fly. They can save time while moving between quest objectives, farming locations, towns, and other destinations.
A simple rule for new players is to use mounts when:
• Traveling across open ground
• Moving between distant quest objectives
• Returning to farming areas
• Exploring zones without useful vertical routes
• Crossing long stretches between activities
Mounts do not replace AION 2's wing system, however. Daevas can still use wings to fly or glide, making vertical movement an important part of exploration.
Why Auto Loot Matters
The auto-loot function can be particularly useful for players who spend a lot of time farming. Without convenient pickup, stopping after every group of enemies can make grinding feel unnecessarily slow.
With a companion providing auto-loot support, players can spend more time fighting and less time running around collecting drops. This becomes increasingly useful during longer farming sessions where dozens of enemies may be defeated in a short period.
Players who want to buy Aion 2 Items should still treat companion utility as a separate part of progression. Gear improves combat performance, while a useful pet can improve everyday efficiency.
How to Start Your Companion Collection
New players do not necessarily need to wait until they have explored every corner of Atreia before getting their first companion. AION 2's launch rewards provide an early starting point.
The pre-registration rewards include Pagati as a guaranteed companion pet. Players can also choose one additional reward from:
• Black Smoke Murute
• Konutin Worker
• Silver Blade Rotan
• Papis
This gives new Daevas an immediate opportunity to personalize their collection. When choosing, consider which appearance you prefer, since these early companions can become part of your everyday travel setup.
Mounts vs Wings
It is easy to think of mounts and wings as competing movement systems, but they serve different purposes.
Ground mounts are better suited to:
• Long-distance ground travel
• Open areas
• Quest routes
• Farming circuits
Wings are useful for:
• Vertical exploration
• Reaching elevated areas
• Crossing gaps
• Navigating areas designed around aerial movement
Learning when to switch between the two will make traveling around Atreia much less frustrating.
Are Premium Companion Rewards Worth Using?
AION 2 also has premium launch packages containing additional companion rewards. The Ultimate Founder's Pack, for example, includes a Black Dragon pet.
These rewards can be appealing to collectors, but new players should not assume that a premium companion is automatically required for normal progression. The core value of the system comes from having useful companions available for travel, collection, and convenience.
If you are comparing cheap Aion 2 Items for your early character, remember that companions and equipment solve different problems. Build your gear around your class first, then choose companions that fit the way you actually play.
Best Way to Build Your Mount Collection
There is no need to collect every companion immediately. Start with the pets available to you, then expand the collection as you explore more of Atreia.
A practical approach is:
1. Pick a companion you enjoy using regularly.
2. Learn when ground travel is faster than flying.
3. Use auto-loot during extended farming sessions.
4. Keep an eye out for new companion rewards.
5. Collect unusual creatures as you progress through the world.
For players who enjoy both progression and collecting, mounts give exploration another long-term objective. Instead of treating every creature as a cosmetic reward, look at how it fits into your daily routine.
Final Mount Tips
AION 2's companion system works best when you use it as part of normal gameplay rather than treating it as a separate collection feature. Mounts make ground travel easier, pets can reduce the effort involved in farming, and wings remain essential for aerial exploration.
As you prepare for the global launch, Aion 2 Items for sale can help you plan your broader character progression, while companions provide convenience and personality along the way. Choose a pet you like, learn when to ride and when to fly, and gradually build a collection that makes your time in Atreia more efficient.
