No CAM signal reading
Drawkk
Beitrag von Drawkk »
hello guys
i'm encounter an issue with cam signal. No problem with crank signal.
i'm running an kdfi ms2motherboard with an brand new sm3+ daughter board with ms3 firmware on a bmw m50nv engine and I want to go full seq. but I can't see any cam signal on my composite logger..
Engine is running but cam fault indicator and halfsync is showing on tunerstudio.
Initially only 3 coils where fired because Kdfi is driving coil by Spark output A1,B1,C1,A2,B2,C2 but the SM3+ is only driving A,B,C,D,E,F so I've linked IGN_D1,E1 and F1 from the motherboard on the Gate of the IGBT according to firing order.
Now all my cylinders are firing but I can see there is twice more spark on the 4,5,6 coil than 1,2,3 with a timing light.
Here is a picture of pin assignement on the kdfi motherboard and sm3+
Here is a pic of my ecu connector pin assignement
CAM sensor is VR. ECU Pin 16 wired to VR2_P and pin 44 to VR2_N. Shield to a ground on ecu.
So for explain I've tried multiple thing.
First I've found that the two VR2_X pin on the kdfi motherboard where connected so I think there is a problem in the board.
To workaround I've directly linked the ecu pin 16 and 44 onto the sm3+'s VR2_P and VR2_N pin like show on the picture. And I didn't touch the sensor shield wire.
Since I've done this, my TPS signal wasn't read on tunerstudio too. When I check voltage on analog signal TPS input on the sm3+ I can see 1,2v decreasing while not touching my throttle and tps indicator on tunerstudio going wild.
I've checked continuity between my sensor and VR2_X when everything is connected and this seems good.
I've check the voltage while engine running between VR2_P and ground and I found 2,50V. So I think my sensor is sending signal but SM3+ can handle him..
I hope someone can help me.. thanks guys
2021-12-12_12.57.59.txt
change .txt to .mlg
(301.41 KiB) 1773-mal heruntergeladen
2021-12-12_13.48.55.csv
(3.09 MiB) 1623-mal heruntergeladen
m50b25_kdfi_ms3.msq
(285.66 KiB) 1587-mal heruntergeladen
