Roy Campanella is one of the biggest rewards in the MLB The Show 26 8th Inning XP Path. The legendary Dodgers catcher is one of two 99 OVR Boss choices, with Ken Griffey Jr. being the other option. If you are looking for a high-end catcher who can make an immediate difference at the plate and behind it, Campanella deserves serious attention. Building enough MLB Stubs can also help strengthen the rest of your Diamond Dynasty roster while you work toward the Boss Pack.
How to Unlock 99 OVR Roy Campanella
Campanella becomes available through the Boss Choice Pack at 275,000 XP. The 8th Inning program launched on September 25 and runs until October 23, giving players several weeks to reach the final reward.
Other notable rewards along the path include:
• 47,500 XP: 99 OVR Negro Leagues Series Mule Suttles
• 160,000 XP: 99 OVR Retro Finest Jake Arrieta
• 275,000 XP: Boss Choice Pack
• Packs and Stubs throughout the XP track
Once you reach 275,000 XP, you can select either Campanella or Griffey Jr., so your current lineup should play a big part in the decision.
8th Inning XP Missions
The program includes several straightforward missions that can be completed across different Diamond Dynasty modes. The main objectives are:
• Win 5 games on any difficulty
• Earn 500 PXP with Cornerstone Series players
• Record 30 hits in Weekend Classic or Ranked
• Collect 41 extra-base hits
• Score 63 runs on any difficulty
The 41 extra-base hits objective is a particularly fitting reference to Campanella, who hit 41 home runs during his outstanding 1953 season.
Players looking to buy MLB Stubs may also want to improve their lineup before tackling the longer objectives, but the XP path itself can be completed through regular gameplay.
Fastest Way to Grind Campanella XP
There is no need to force every mission into one mode. Instead, stack objectives whenever possible.
For offline players, Play vs. CPU, Conquest, Mini Seasons, and Diamond Quest are useful for accumulating runs, extra-base hits, PXP, and wins. Load your lineup with Cornerstone Series players and power hitters so several objectives progress at once.
The 30-hit mission is restricted to Weekend Classic or Ranked play, so online players can work on it during their normal games. If you prefer offline content, simply focus on completing the other missions first and return to the online requirement when needed.
There is another major shortcut for returning players. If you collected both David Wright and Manny Ramirez, the 99 OVR 7th Inning Bosses, you can receive a 30,000 XP voucher for the 8th Inning path. Weekly Drop Missions can provide additional XP as the program continues.
Roy Campanella Card Attributes
The 99 OVR Hall of Fame Campanella is built around excellent hitting numbers. His key attributes include:
• 113 Contact vs. LHP
• 104 Contact vs. RHP
• 120 Power vs. LHP
• 104 Power vs. RHP
• 110 Vision
• 110 Clutch
• 90 Fielding
• 90 Blocking
• 91 Pop Time
That combination makes him more than a bat-first catcher. He can handle tough at-bats while providing reliable defense behind the plate.
Campanella also has eight quirks, including Dead Red, Breaking Ball Hitter, Fighter, Rally Monkey, Situational Hitter, and Table Setter. His secondary positions include third base and all three outfield spots, although catcher is clearly where his skill set makes the most sense.
Campanella or Griffey Jr.?
The Boss Choice is ultimately about roster construction. Griffey gives you an elite left-handed outfield bat, while Campanella addresses one of the most important defensive positions with exceptional offensive numbers.
If your catcher position is already stacked but your outfield needs another power hitter, Griffey may fit your lineup more naturally. On the other hand, cheap MLB Stubs can help you make other roster upgrades while allowing the free Boss reward to fill a position that needs improvement.
Final Tips
Start the 8th Inning path early instead of waiting until the final week. Focus on missions that overlap, use power hitters to build extra-base hits and runs, and keep Cornerstone Series players in your lineup until the PXP objective is finished.
Once you reach 275,000 XP, Campanella gives you a legitimate endgame catcher with elite contact, power, defense, and clutch hitting. For players still preparing their squads for upcoming Diamond Dynasty content, checking MLB Stubs for sale can provide additional roster-building options while you chase one of the strongest Boss rewards in the 8th Inning program.
