Vr6 turbo with Kdfi v1.4 PnP
fredoux
Beitrag von fredoux »
Hello,
First of all, excuse me in advance because I do not speak German and I block for several weeks on this problem.
I am contacting you for information on Kdfi equipment.
I bought a kdFi V1.4 PNP VW AAA calculator (VR6) but I have a problem to start the engine (Golf 3 vr6 turbo).
Indeed, I am in wasted spark like this :
http://www.strperformance.com/4625-larg ... 8l-29l.jpg
Does it work too or does it absolutely need the ABV kdfi?
With the original vr6 OEM calculator the car starts without problem so it is not a problem of setup.
The sensor Vr/hall is new (same pb)
Thanks for your support (in english please or i traduct with google). :idea:
2018-01-24_15.42.43.msq
My Msq file to start the engine
(89.21 KiB) 520-mal heruntergeladen
Pb with Vr/hall sensor ?
Zuletzt geändert von fredoux am Do Jan 25, 2018 11:00 am, insgesamt 1-mal geändert.
Re: Vr6 turbo with Kdfi v1.4 PnP
Which pattern does your trigger wheel have? The second peak indicates a second gap. Is it really a x-1-1 or a more conventional x-1 wheel?
Regards
Zuletzt geändert von Dominik335i am Do Jan 25, 2018 11:36 am, insgesamt 1-mal geändert.
fredoux
I am on 02M (V6 4motion Gearbox golf 4) with Sachs Performance/Race clutch and Flywheel.
I hope you understand my setup
Yes, but this does not answer my question ;-) Is it a 60-2, 36-1 or what ever trigger wheel? The tooth logger must correlate with the pattern.
In case of a 60-2 wheel it should look like this:
36-1
fredoux
Hello !
60-2
Then you have to sort out your trigger issues! Is it a hall or vr sensor at the crank?
Btw.: The german translation is crap. I assume it's not very different with the french one :-) Hence most people prefer the original english language version...
fredoux
No pb !
My engine sensor RPM : Bosch 0261 210 107
And this : http://www.strperformance.com/5715-thic ... 8l-29l.jpg
It's VR
Or can I find a startup file vr6 turbo turbo if I give you my configuration. The mappers do not arrive and maybe I can compare with a functional config
It's essential to have a proper tooth logging. You have to sort out the trigger signal issue and clarify the reason for the second spike. Everything else is a waste of time.
Once you have a proper signal and everything is wired up correctly, the engine will start with no doubt after some tweaking...
fredoux
I searching why i dont have a good signal, is my question ..
fredoux
I will try to inverse VR+ and Vr- somebody has tested that ?
Just try it ;-) Do you have access to an oscilloscope?
fredoux
I think i can to access why ?
To check the "raw" signal of the VR sensor?! :roll:
fredoux
Ok i will try this.
Where can i found msq vr6 turbo who start the engine ?
Thats why k data production are not good.
Sold as plug and play (yes the connector fits - that’s all), no support nothing.
Read the MS manual please.
